Originally Posted by pete c
what ^^^^^said. combustion takes time. that is why ignition always takes place BTDC, never after.
Yes But in a normal engine it is like that.
I have modified mine.
My engine needs to be fired -3.67 Deg @ 750 Rpm eg 3.67 Deg ATDC to avoid knocking.
I measured what my computer was doing and the Trigger and Firing pluses have been stored on a MP3, anyone can download them and convert the MP3 to a Wav file, then use a good sound editor to work out the timing.
Note: the offset is 62 Degrees BTDC and the Degrees between pluses is 180 for a 4 cylinder 4 stroke engine.
Timing confirmation jan 2013 by smokingwheels on SoundCloud - Hear the world
The file name stores the info.
750-rpm-65-7-d-3-67-set-2-1
rpm =750
total timing = 65.7 deg
d = -3.67 (Actual timing 62 offset)
set = -2.1 (what the computer is tring to run the engine at with 62 offset)
