Old 06-18-2008, 09:13 PM   #335 (permalink)
ttoyoda
ttoyoda's Avatar
My power supply is a 130w power supply from an old PC, so it should be nice and clean. I put some taps on the front for the 5v and 12v and it works just fine. A good cheap trick for an already engineered power supply with multiple voltages!
I always though that these supplies needed a significant load to actually give the correct voltage. Have you had a chance to measure the voltages when the duino is the only load?
