New O 2's can be found pretty cheap on ebay, and they can make a big difference if they get fouled or lazy. slow responding, I think you'd be fine with a bit taller tire as i run 5 th gear at 40 mph with no problems on the level .I'm running right now 185's 65 14's as i have wider custom wheels that came with the car , My power steering is leaking right now, is it easy to switch to a manual rack on a 98. or can I just pull the belt, doubt it would work the way they run it but certainly harder to work on than the Ranger
