Old 03-17-2013, 03:39 PM   #40 (permalink)
oil pan 4
Just adding a turbo charger will add 30 to over 80 pounds depending on the application.
Adding a Rankine cycle would add much more weight for small gains.
For example classical boiler design calls for 10 to 12 square feet surface for each horsepower you hope to generate with a Rankine engine.
My turbocharger and added piping weighs about 60 pounds and generates about 40 horsepower worth of compressed air the way I use it, but I only use about 1/3 its max rated output.
The turbocharged diesel has no problem producing 2 to 3 times the horsepower and 10%-20% better fuel economy over an N/A diesel.
