Old 06-18-2008, 11:26 PM   #31 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
the mpguino NEEDS to be connected to the 12 volt battery so if there are any vss pulses or injector pulses it will still count them. If you EOC without an ignition kill switch then you might not get readings while the key is off, but only because the car stopped sending them. The readings should return when the key is turned back on.
