Old 03-17-2013, 07:15 PM   #4 (permalink)
HydroJim
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
brucepick- I think you understood what I was talking about. I had a hard time describing it.
the M.C. escher-esque thing you are seeing is just an optical illusion from this angle. the square tube chassis is essentially a box and I was wondering if I should have the top edges of the box follow the contour of the F16 canopy. I believe it shouldn't affect performance much because the air has to be moved out of the way one way or another
The wheel fairings will be tapered, I just didn't feel like drawing it in because it's a lot of time and I already have it visualized well in my head.
pete c- I think you're right about the leg room. A lot of my specs are guesses so I may need to extend the passenger compartment slightly.
My budget for this build is $3000 so I was planning on using ATV parts for the front upright/spindle/hub/rotor/caliper set-up. the a-arms will be custom and I will be using civic VX wheels.
The edison2 suspension would allow me to fully fair the currently exposed suspension area so that would be nice. I guess I'll contact them and see if I could get something on the cheap.
right now my track is at 67 inches, so I'm not sure if I'd want to go much farther out
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
