Old 03-17-2013, 09:06 PM   #41 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Air-Hybrid View Post
Unless there are practically no COs or HCs present in the exhaust I believe the cat' temperature is self-sustaining; plus if adding an exhaust turbine presents problems in holding the heat up enough, can't exhaust wrap be fitted?
Exhaust-wrap has many advantages, since it even optimizes the exhaust flow. It's also favorable to aeromods, since it requires a smaller clearance between the body panels and the exhaust pipes when some compound materials are used
