Originally Posted by cRiPpLe_rOoStEr
Diesels are getting smoothier nowadays
Take a Mazda Miata, delete the P/S and A/C, do some moderate aeromods, get some lighter front fenders, engine hood (occasionally could get a single-piece front clip), doors and trunk lid, and then you'd have a good base for such project...
A miata is rear wheel drive with a differential... the Razor uses a FWD drivetrain in the rear. Plus after all is said and done... you still have a miata
Originally Posted by Cobb
You would need to remake the cooling system for the battery pack. Maybe put it under the seat with a reusable filter and a water trap to keep it dry. If you plan on having heating or cooling make sure a vent goes into the cooling system for the pack as well.
True... I'm sure there would be a lot of things to work out. I don't know the dimensions of the battery pack. If I were to seriously do it I would contact SLC and tell them what I'm doing. That's what is so nice... since they are a custom car company they will work with you.
