Old 03-19-2013, 04:47 PM   #11 (permalink)
user removed
Another advantage is the fuel can absorb engine heat which improves atomization. In the return systems a lot of that heat was returned to the tank and over some time would warm it up measurably and, as previously mentioned, increase evap emissions, which are generally offset by reduced fuel delivery from the injectors.
regards
Mech
Blue Angel (03-19-2013)
