Originally Posted by razor02097
A miata is rear wheel drive with a differential... the Razor uses a FWD drivetrain in the rear. Plus after all is said and done... you still have a miata
The Miata not an impressive vehicle after all, but is a good base for ecomodding. As one of the few compact front-engine RWD platforms currently available, it's a good option to play with many different setups
Including eventually throwing an FWD drivetrain inside its trunk
