Old 03-20-2013, 11:18 AM   #13 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
PC is not so easy to score. if this means making a cutting line with box knife and bend it broken. PC does not broke when you bend. That works for acrylic but still tricky if you have to cut over 1 meter lengths. One cut to every 1mm thickness so 3 for 3 mm thick acryl.
jigsaw does not make so straight line easily and you easily scrape the clean surface when the masking plastic gets hole when you have to push the saw towards the sheet.
If you only have to cut only straight circular saw/table saw works great for PC. For acrylic you need to cut over 3mm thick sheet. On smaller thickness it tears the edge quite easily if you dont have very sharp saw blade.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
