Old 03-20-2013, 12:03 PM   #14 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
Using a Jigsaw at a lower saw rate of any TPI blade with PolyCarbonate works well since, it does not break easily if at all if your needing a slight curved shape or edge to contour whatever it is your trying to match it with. Acrylic is best scored, but if you get it thick enough, you might be able to use the jigsaw again with a finer TPI blade with it against a VERY sturdy backing, this also applies to Lexan as long as it has sufficient thickness.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
