Old 03-20-2013, 04:27 PM   #24 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I was thinking about the heat exchangers which cool down EGR gasses with coolant (like in most new turbodiesels): We ecomodders want to run our engines hotter than normal, but then the coolant is also hotter, so there is less EGR cooling. So in a gasser, why not use intake air for cooling? It is almost always colder than coolant, it works like a WAI, and if the HX gets a leak, then there is not too much wrong with some exhaust gasses seeping into the intake.
