Old 03-20-2013, 09:59 PM   #4 (permalink)
aerohead
confusing
Originally Posted by Sven7 View Post
That would be really cool since I now park outside all day every day. But the power is confusing... when they list XX watts, what time span is that in? It will put out XX watts in one hour (watt hour)? One day?
between 10:00 AM and 2:00 PM under clear sky,if pointed into the Sun,you might expect the panel to produce that much power.
If at 12-volts,you'd divide the power by 12,and that would give you your charging current in amps.
