Old 03-20-2013, 10:47 PM   #292 (permalink)
NeilBlanchard
The glue is part of it - I used about 3.5 gallons, and the dry weight of that is probably about 4lbs/gal so say 15 pounds of glue? The glue and the foam together are maybe about 100 pounds? Total WAG, you understand. I'll attempt to weigh it without the plywood later this Spring.
I can hoist the back up with one hand, and the front can be lifted, as well. I made a litter frame out of 1x3 wood strapping, and two people can carry it with that.
