Old 06-19-2008, 04:57 AM   #1 (permalink)
Vince-HX
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 honda civic Hx
Last 3: 58.02 mpg (US)
Project HX - The flip side
I'm totally addicted to mpg and i'm not afraid to admit it
My current ride is a worn in (180,000) mile 96 Honda Hx. When i first bought the car the best I could do was high 30's but that was before I discovered the world of hypermiling.
My Hx is setup mostly stock with a full suspension upgrade, 15's and grippy 205-50-15s, and a Full-Race traction bar. I compare it to riding a Ninja 250, small, nimble, but if you want to go fast around corners you have to go fast into corners. Anyway it rides and handles great but right now with my MPG kick I could sacrifice a little here and there.
I swapped a Ex tranny into it before i knew what the hell i was doing and now I'm guessing I'm loosing out on 5-7 mpg because of the shorter gearing. And the current wheel and tire combo is a little small (speedo reads a little off but odo is gps verified). A Cx tranny from a Eg chassis should put my rpms where they should be soon.
My latest mods have been side mirror deletes, upper grill block, vacuum gauge installed, front lip, tune-up. My last tank checked out @ my best yet - 48 mpg
In a few days I plan to have my hands on a set of Hx wheels and tires for a 28lb rotational weight drop and a SCII. Also if my job doesn't take over my life this weekend I plan to start fabrication of a full fiberglass belly pan and rear wheel side skirts.
I also plan to add extra instrumentation to better monitor the vtec-e and lean burn modes. Right now my vacuum gauge is providing me with some great info and it seems to be working. Its cool to feel and see how a vacuum gauge, throttle, vtec-e, and lean burn all work together but I still feel there is much to learn to maximize my mpg gains.
I also just want to say that Honda's are effin AMAZING
Oh, and I guess i should add that during the day I engineer and fabricate custom stainless steel turbo manifolds. If you guys are interested in that kinda stuff you can check out the site http://ecomodder.com/forum/showthrea....full-race.com.
So yeah, thats about it for now.
I would love to hear any ideas you guys have
And when I achieve my goals and finish all my planned mods I am going on to the next project. It will be a full custom chassis three wheeler, fully enclosed single seater with a ninja 250 engine with sprag clutch combined with a custom small hybrid brushless Dc Regen capable setup. I want, need, 150+ mpg **insert evil laugh**
The pic is pre mirror delete and grill block but gives you guys an idea of what i'm working with.
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
