Originally Posted by DieselX
I guess my question is if there is an advantage to engine off coasting vs. engine on coasting if the pcm cuts fuel when you coast. In nuetral of course.
The computer can't cut fueling if you're coasting engine-on in neutral because there'd be nothing to keep the engine turning.
