Old 03-21-2013, 08:46 PM   #107 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Your bike reminded me of some of the streamliners I used to race against. A plastic nose with a coroplast and fabric in back.It is a good start. 100 mpg is nothing to sneeze at. Kudos.
For a more substantial rear portion. You can use aircraft type of construction. Steel framework or other framework then covered with dacron (polyester) fabric. A heat gun will shrink it tight as a drum then it can be doped.
You won't trash your lungs with grinding composite.
The nice part about using steel is that it can be welded together with a cheap welder making it virtually one piece.
BTW wear a face mask around that stuff.
Noah Webster, 1787
The Following 2 Users Say Thank You to Varn For This Useful Post:
aerohead (08-30-2013), renault_megane_dci (03-22-2013)
