Originally Posted by RedDevil
I'd like that too, if just to balance the cells in my battery pack. Over time the load level between individual cells in the battery pack will start to differ; while some are almost empty others will be full. This will reduce the effective range of the battery pack and may damage the cells as they get underdepleted or overcharged.
A gentle overcharge may top off all cells while those that are already full will not get damaged. A trickle charge will not only give better initial performance, but better performance all round.
It's the not knowing how to that's holding me back for now.
I have tried this with my Prius, a charge at a low rate (100mA) does not equallise the cells, it actually seems to make them more unequal...which supprised me, I think it is because the self discharge is so temperature dependant and the most full cells get warm and end up the lowest.
