Old 03-22-2013, 11:05 AM   #5 (permalink)
Cobb
You are right, it does not work on the prius cells. It only works on the cylinder cells. The charge used is 350ma, which btw is what most wall warts use to charge nicad batteries. The non US models had a charger included in the trunkthat did something similar in a different way to revive a low or bad pack.
