RD, you are in Europe, I was of the understanding you guys had ready available adjustible power supplies and it was just a matter of hooking one up, setting it to 134 volts no load and 350 ma output and wait 36 hours.
Its likely your 12 volt battery that is so-so. I bet if you switched it out you see a vast improvement in your IMA behavior.
