Originally Posted by Rusty94cx
Also if the 02 is going bad you will get no sil. Does the check engine light work? Come on when starting car then go out? If you have the light in while driving you will also have no sil. Good luck.
The O2 sensor is new. The CEL definitely works and is not on while driving.
