Also if you still have a wheel bearing noise a good way to tell is it will increase with vehicle speed. Plus at speed if you turn the wheel to the left or right the noise will get louder or quieter. Don't always go by " it sounds like the right side" I've had to eat parts in the past because it sounds like the noise is the right side but it's actually the noise/vibration traveling across and fooling you. I have a diagnostic procedure for hub/wheel bearings to determine which side it is. I can share if you like
