More detail. Which car? Will the starter try to start the car, etc. What did you do to get it to restart? First things I would check are all battery connections (including grounds) and the neutral safety switch. Try starting it in neutral when stationary to help rule out safety switch.
One other thought, if the place were you got the battery has free testing do it, this will rule out any charging or battery issues. More likely the problem is something else.
