Old 03-23-2013, 09:46 AM   #5 (permalink)
radioranger
radioranger
Pretty good mpg with the auto, my 88 gets around 26 27 I took a sheet of plywood and covered the last four feet or the bed letting it hang over maybe 4 inches the tailgate area, seemed to give me a full 1 mpg with just the cover, i recommend going to the redline lightweight shockproof gear oil for the rear diff, maybe a full mpg there, plus gear will last forever, or near as you can get, summit has it , definitely noticeable power increase, also make sure the brake shoes are properly set up with lube on the rubbing points of the backing plate, , they can stick a bit looks good though nice job on the front.
