The manual says that this car can be flat towed.
The time almost died, I probably shut the engine down 50 times in that trip alone. So that means I just need to trickle charge every night to keep it healthy? I have to park on the street so it would be a bit difficult to charge at night because I don't know if the Extension cord will stretch across the street and the battery charger is an old, big kind that only has a time dial. Not a "smart" charger.
I did however clean the throttle body and IAC. On startup, it revs high then drops down to 1200 or so. Same in neutral at a stop. But only on start up. After it idles at ~800 at a stop in gear (not me driving). Any way to fix that first?
 : Brothers
 : Dad's
