Also know that not all gas gauges installed in cars are quite accurate for monitoring the exact amount of fuel in the tank. The tank in the van I drive can hold 20 gallons of fuel and although it's currently running below E, According to the ScanGauge II over seven gallons are left. (You can use a Scangauge II to monitor how many gallons are in your gas tank; If you buy one, Read the manual fully so you may use it to its largest potential.)
(The ScanGauge was not calibrated when I posted the above text on 2013 March 23, Take the above statement with a grain of salt.)
