Old 03-24-2013, 10:16 AM   #305 (permalink)
Jyden
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Originally Posted by Vekke View Post
One layer is nowwhere near enough. He is using twill and if the weight is around 300 g/m2 6 layer is 1,6mm so one layer is ~0,27-0,35mm. Now imagine that you have so thin layer of glasfiber and you need to start sanding it smooth. Although the foam looks pretty smooth in the pictures there will come lots of holes to the capsule when you start sanding and adding plastic padding.
You forget he's making a sandwhich construction. And the fiberglas should NOT be sanded down. Wowen cloth should be used, and filled with epoxy, and then the epoxy sanded smooth.
You can NOT compare a sandwhich to a monoshell. Sandwich is MUCH stronger.
My Yaris Hybrid thread:
http://ecomodder.com/forum/showthrea...s-c-27995.html
