Old 03-25-2013, 04:21 PM   #16 (permalink)
TheSGC
Why do you say they need trickle balancing? You should be able to do this, but only to 6 cells at once because that is the most that the PL6 can handle.
Some of the documentation I've been reading on these cells say that they should "balance" themselves a bit when they reach full charge, then are put onto a trickle charge after.
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
The Following User Says Thank You to TheSGC For This Useful Post:
Daox (03-25-2013)
