Well that's interesting, I always thought that the 1.0 4cyl engine would be better than the 3cyl (stronger and better fuel consumption). Because as probably as you can see in my garage tourqe on my Corsa is only 88NM @ 3800rpm. And I can't imagine that the 4cyl version would have lower tourqe than this. But if you say so, it must be true. Also I have never seen a 1.0 8v Corsa in my Country, all the corsa-s with a 1.0 engine were 12v 3cyl models. My Corsa C has the latest 1.0 12v engine with twinport system, two O2 sensors but if you ask me 5,5l / 100 is to much for this engine, it must be possible to get it somehow lower. Because my friend in a Toyota Yaris 1.0 16v manages to make 4,5l / 100.
Every day I see my dream...
