My previous car, a Nissan Almera, was hard to fill to capacity on the level and would take over 2 gallons less when the side with the filler cap was slightly lower.
Used to park it on the wrong side when sloping towards the pump. Maybe this applies too to the 500?
Also cold weather, esp. cold starts, really ruin FE. If your commute is shortish that alone would explain the fallback.
Bet you will get 50+ mpg from that baby by summer
