Thanks for all the replies guys, I will try to answer some of your questions so you guys can have a better idea on how to help me.
I park the car in a underground garage which is I am guessing around 35-40F. I don't run the defroster all the time but I do only use Defroster + Leg setting. Which means when I want to warm up the car, not necessarily to defrost the windshield, I turn on the defroster + leg. Does defroster uses more energy compare to just regular hot air (like the leg only, or upper body etc).
I have recently changed the engine oil to synthetic and changed transmission fluid.
The threads on the tires are pretty worn out, I have about 3/16in left from the minimum thread rib (this car has 35k miles on it).
I try my best to coast the car but you know in cities, other drivers are always up your a**.
I am currently only trying to find out first of all, does this car have a problem. IF NOT, what can I do and how much I can improve the mileage with just driving techniques.
I don't want to mod the car because it would skew the result, since this car is a lease and I got a good deal on it, I can afford to sell it at a reaonable lost and change to a new car.
