Originally Posted by AndrzejM
Check spark plugs and lambda sensor. I know probably for such short commutes engine will stay in a open loop but I think that Accord has heated lambda. You may check inlet manifold for leaks, and exhaust as well.
If I'll think of something more I'll post.
What do you look for on spark plug and O2 sensor? There is no Check Engine Light, so beside to see if it is visually dirty, how do I know if they are affect anything?
This car is pretty new, 2009, do you think it is possible to have manifold leak and how do I even go about checking it?
