Old 03-26-2013, 05:41 PM   #1 (permalink)
renault_megane_dci
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
cylinder deactivation
In my quest to meet the best of both world (FE for cheap) I am contemplating an other axis then atkinsoning a bike engine (GPZ / EX).
I like the concept but :
A/ it needs to be a definite modification (to keep it cheap) and I like my power blast here and then
B/ it might not even match the FE of a regular 250 bike
C/ there are a number of unknown, most worrying of all is the functionality of carbs on a breathing back engine
The other option is to deactivate on the push of a button one of the cylinders of K7 and UP Suzuki SV.
K7 is because they are injected and I believe all is required is not to inject in one of the cylinders.
Then I end up with a 325 engine with a drag penalty.
It is also over geared for its capacity wich is a load booster (pumping losse minimizer)
Do you think it is a worthwhile idea ?
Do you think I need to have the throttle body of the dead cylinder fully open, fully closed or still linked with the live cylinder throttle ?
I believe it might return the same potential than an atkinson EX 500 but with the ability to have the full monty whenever needed.
The Suzuki SV is also a much nicer bike with a higher resale value.
Also, said mod does not need to make my hands dirty.
I can even go crazy and atkinson it (I believe 99 to 07 models have shorter camshaft than 07 to ? models) and add the cylinder deactivation on top of that !
