In order to make cylinder deactivation work via shutting off fuel injectors, you'll need to do the following:
Coat your spark plug electrodes with latinum,
Get a quality motor oil with a tritanium-based wear additive,
Obtain some SeaFoam Plus with Neutronium (tm), and pour the contents into the throttle body with the engine running at 1000 RPM, and
Get some STP Fuel Treatment with corbomite, and follow the instructions on the bottle.
