Old 03-26-2013, 10:16 PM   #34 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Honda100 View Post
I thought about it (diesel swap), but there are a few main problems that I've seen with swapping the Atoz, mainly it's space. Even the little petrol 800cc barely fits (this car is very annoying to repair), and then there's the issue of the transmission which has a cast in bellhousing.
I wouldn't disconsider some 800cc 2cyl Diesel if it was easier to overcome the transmission issue. Yesterday I saw a Hyundai Atos in my hometown and started to lurk about a setup similar to those rear-engined autorickshaws from India. There are even some with Kubota single-cylinder 9hp engines (altough I'd rather get a twin-cylinder if I were messing with an Atos)...
Of course it wouldn't be a problem if Hyundai had a same bell pattern diesel, but they don't, and I don't see an adapter being able to fit either.
Hyundai even had some factory-fitted Diesel versions of the Atos, with a 1.1L CRDi 3-banger, but it was only available with manual transmission
