^^^ good info
get a UltraGauge as well. the #2 o2 sensor reading will tell you when you are in lean burn. and the TPS will give you info too. below 20% it will pop into lean burn, above 20% it wont. once in lean burn, keep the TPS below 30% and it will stay in LB. getting into, and staying in LB is the key to MPG w/ the HX. the UltraGauge will help A LOT with this!
2000 Honda Civic HX with mild aero mods
2006 Honda Insight MIMA, FAS, no passenger sideview mirror, race style drivers mirror, front and rear underbody aero, temporary front air dam
