Old 03-27-2013, 11:40 PM   #33 (permalink)
Shortie771
Eco Sol
Shortie771's Avatar
Originally Posted by Smurf View Post
No sarcasm at all. I'm still plotting everything. Instead of acting, I overthink. You thought it quick, worked it out, and implemented it. I'm genuinely impressed.
Well thank you very much
Still a few tweeks to do on it. Need to find a way to reinforce it a bit, it is starting to sag in the middle slightly. I also need to add a bit of weight to it so that it closes just a bit later.
I was kind of thinking maybe a very thin coat of fiberglass resin (no glass) might be enough to do both jobs at the same time by adding strength and a bit of weight. Anybody think that this would be a bad approach?
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
