Old 03-28-2013, 04:05 PM   #35 (permalink)
Shortie771
Eco Sol
Shortie771's Avatar
Originally Posted by Swordsman View Post
This is way cool! I wonder if I could rig up something similar with sheet aluminum for the gaping hole in the front of my Mustang?
~SM
Absolutely, it wasn't very hard to make actually. I will take a few more pics of the nearly finished project. I think aluminum might also have the same strength issues I am having, so you may want to find a way to make it more rigid as well. You can either cut away your grill (if it doesn't clip/screw on) like I did to install this, or you can simply install it behind your existing grill (a bit more drag that way I would assume) for a more stock look. If you decide to install it behind your factory grill, I would suggest removing your bumper to make installation easier. It would be pretty difficult to install behind your grill otherwise.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
