play around with the UG's power on/off options. there is a way to keep the UG on when the ignition is on run its different per car/make/model. Just make sure it turns off when the ignition is off or it could drain the battery in the matter of 48hours
"The only real mistake is the one from which we learn nothing."
- Henry Ford
