It is a manual, so if you leave it in gear the engine revs according to the speed you move.
If your Scion had an auto without lock-up or with disengage then of course the revs will go down if the load does too. If it has a CVT then sure the revs go down. Unless, like me, you give it so little that it cruises in its most extended position.
