Old 03-29-2013, 10:02 AM   #34 (permalink)
kach22i
Originally Posted by Swordsman View Post
......I see you mentioned conveyor material...
Do some forum searching to find out what you like best.
Conveyor belt material is what the track guys use because it takes a lot of abuse. Some may use aluminum as it is soft and will burn or burnish away quickly enough.
In the past I have used sheet metal with garage door seal, and garden edge trim with vinyl cove wall base.
With your situation and being so close to the road, you are similar to the race car or track car solution in my opinion.
