Old 03-29-2013, 11:03 AM   #13 (permalink)
hungryhunter
Originally Posted by Old Mechanic View Post
Why unplug the knock sensor? I think that would hurt your mileage. Will probably set the check engine light.
I think a 195 t-stat would be fine but you might check to see what was offered as original equipment.
regards
Mech
I read on here somewhere that Ford even recomended unplugging the KS. It was too sensitive and will retard your timing even when there is no ping present. I'll try it. I can always plug it back in. I just filled up and calculated an actual 35.7 mpg for 225 miles mixed city/hwy. I want to get to 40.
1999 Ford ZX2
