Old 03-30-2013, 07:08 AM   #6064 (permalink)
jackbauer
jackbauer's Avatar
First fit of the igbts on the heatsink with Adam's driver pcb. I can use one set of the pre-drilled holes for the middle igbt but will have to drill and tap for the outers. Sadly the azure design for the ac controller had the 3 igbts spread out all over the plate.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
