Old 03-30-2013, 08:46 AM   #108 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
The switch works the way that if it's on "0" then both circuits are opened, rocking it to I or II positions is switching on two separate circuits. One for cutting off the engine - electrovalve on injection pump (diesel), second one starts the engine with a starter. if it's in "0" it works like a normal oem setup. I've used two relays one normally opened for a starter, second one is normally closed for feeding current to electrovalve. So when I press the button is switches relay from normally closed to open position and electrovalve cuts off the fuel.
It works great. I have to control over the engine with just my thumb.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
