Old 03-30-2013, 11:25 AM   #19 (permalink)
TheSGC
I don't know if you saw MetroMPG's thread on reviving his insight's nimh pack. He had to cycle them multiple times to 'revive' them to their full capacity. Each cycle (at least for the first few) ended up showing greater and greater capacity.
How many times did you cycle it? What is the rated capacity?
I only did one cycle, and it's rating is 85 AH. I definitely need to cycle it more, I just need to fine tune the PL6 to meet the specs of these Ovonics. I probably need a good 5 or 6 cycles per battery to get a proper capacity reading. I also need to setup my lead acid battery bank to be the source for the PL6. I am going to set it up with 3S2P for 24 volts and ~200 AH of lead so I can use it as a regenerative charging source.
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
