Originally Posted by betasniper
[CENTER]T The Red Car which is in the traditional "blind spot" would be perfectly visible in the "new" setup. When the Red car is starting to leave the side view mirror, it enters the drivers actual field of vision forward from the B pillar.
On the other hand, when you are driving at night, the red car will have his high beams on (as will the others), leading to a 360 degree blind spot.
