Originally Posted by cRiPpLe_rOoStEr
One feature from the motorcycles that I like is the mounting of the magneto right in the same axis of the crankshaft, so no belts, no pulleys. In a no-frills car it can also work decently, I've already seen it done into some Volkswagen air-cooled engines, but since their alternator (or dynamo in older ones) is usually bolted to the engine-cooling fan it ended up requiring a different fan setup.
...the original Ford Model A worked that way too as I vaguely recall...generator integrated into the flywheel.
