Old 03-31-2013, 02:18 AM   #7 (permalink)
AaronMartinSole
Your car looks ridiculous
The Fantastic Festiva - '90 Ford Festiva L
90 day: 43.16 mpg (US)
A Civic Duty - '96 Honda Civic LX
90 day: 34.9 mpg (US)
Ranger Danger - '96 Ford Ranger XL
90 day: 17.42 mpg (US)
At lower engine speeds the engine is already closer to the peak torque, due to a broader torque band, and also the torque is greater than a non-turbo version of the same engine. So, keeping the RPM lower while the vehicle goes at a given speed in both scenarioes (turbo and aspro) is the key for the turbocharged get a greater efficiency. The higher torque also deals better with taller gear ratios.
I- I... I wish I understood. So... should I just keep driving as I am, light on the throttle, not activating the turbo? I go into 5th gear really soon too, like 30, even 25 miles an hour. The RPMs go really low, like 1500-2000 if I remember correctly. That's the goal, low RPMs, right? Maybe it isn't. I don't know. Slow doesn't necessarily mean efficient, right? I don't know what I'm doing. I can use the turbo to go to 40mph really fast and kick into 5th gear. Is that preferable to slow acceration?
