that cnc would be perfect for things like this!! you could even put a bigger bit on for rough cut, then a smaller bit for a finished cut, but I also noticed it has a tipping head, so that might not even be necessary, since you could just program it to make the contours like that...
niel, that means you have just under a month to get it in fiberglass
